i have a motor stuck in the down position due to an apparent hydraulic failure in the lift cylinder. i assume it IS a problem with the piston and not the lift motor because i can hear the motor run in both directions but there is absolutely no lifting happening. 3 questions: 1) where is the manual relief valve on a 95 pro 50? 2) what is the likely failure within the piston. o rings? could it just need to be bled? 3) could a piston overhaul be accomplished by a novice mechanic or should i haul the boat in for service?
thanks
thanks
