Suzuki DF70 alrm Problems and water pump
captain70085
I have a 1999 df70 four stroke i was having problems with the water pump so i bought a water pump kid and installed it. but the pee hole doesn't pee like it used to yrs ago. It pees about 2ft i cleaned the small hose and bough ends where the small tube connects to. what else can i do?
and my check engine alarm keep beeping but everything is fine to me an burning a little oil but not much
help please
JUSTINTIME
Re: Suzuki DF70 alrm Problems and water pump
run some clr in the water pump
replace the t stat
hrafnin
pull off the last piece of plastic where the pee should be, clean.
the check engine is flashing in numbers, (two digits) get back with it and ill check what the code stands for
captain70085
It doesn't have any numbers it just beeps and when i hold the automatic coke in when the motor in running it stops but continues to bleek
captain70085
replace the t stat
how would i run clr in the pump and where are the t stat on the motor im new at this can you give me some details (captain70085@yahoo.com)
JB
Is it due for an oil change? The check engine alarm may be telling you to change the oil (and filter). After an oil change the 'puter can be reset by cycling the kill switch 3 times with the key on and the engine off.
If you don't have an Owners Manual, you really need one. You must be able to read the trouble codes from the light. EFI 4 strokes are very sophisticated machines. If you don't know what it is telling you (and it can tell you a lot) you can very easily kill it.
