Hello, need some help troubleshooting this problem:
1999 OX66 200hp twin, both engines feeding from same tank. After running both at any rpm over 3000, for about 30 min starboard engine starts surging almost like it is starving for fuel. If I throttle back to below 3000 it runs fine but then after 20 minutes it starts acting up again and at one point it will do it also at 2000 rpm . I have taken the following actions but I still have the same problem: replaced water separators, swapped fuel lines starboard to port at the water separators,checked and cleaned anti syphon valve on defective engine, replaced paper filter, replaced 2 low pressure pumps, cleaned VST needle + vst tank, replaced VST filter, replaced fuel regulator + screen + all related o rings and gaskets, cleaned and checked O2 sensor as per manufacturer instructions. I have been running on the aux 50 gal tank with fresh fuel and ring free. If I switch to main same problem. Do you guys have any other ideas?
Thanks in advance for you reply.
jp
jp
