Help! I just purchased a 92 yamaha 225. The compression test was good reading 4 cylinders at 125 one at 127 and one at 123. When we put it in the water the other day we could here the slightest knocking noise coming from under the flywheel. My mechanic thought it could be the upper bearing on the crank and that this could be replaced without tearing the engine apart. He came back and told me today that if the bearing is bad it is most likely a sign of a bad crankshaft all together and the engine would have to be torn apart. I have a second opinion coming next Monday from a local marina that has certified Yamaha techs. Any ideas or comments would be appreciated.
