cigar_stub
- Jun 30, 2007
- 88
Well, I finally got the new tach working on my 2002 Yamaha 115 hp outboard. The Selco manual says WOT is 5500 rpms. When on the river today, with full throttle, I was running about 6200 rpm. I can only assume the new tach is accurate as it zero's out when I turn the key and I idle about 1000 rpm's.
My quesion is this: Is the higher than lister WOT a throttle adjustment that I should try to make? Or could it be the prop is not correct? I believe the prop is the original (the boat is a 2002 Bay Stealth by VIP) and it has very few run hours.
Any input would be appreciated.
