I have a 1987 200 hp yamaha and trying to figure out why the oil tank on the engine is not filling up - My alarm fires when oil is low on the tank but no oil is
pumped into the tank. I can use the manual switch on the control unit and oil is pumped from the reservoir tank on the boat so that pump is working. I can also fill the tank on the engine with oil and the alarm goes away after turning the engine off and on again, so the sensor is detecting correct fluid level --So it does not sound like the oil sensor on the tank, nor the pump on the reservoik tank, + the manual switch on the control unit also works--so what is left?
Any help would be greatly appreciated.
Thanks in advance
Bill.
Thanks in advance
Bill.
