YamaHammer
- Jul 11, 2007
- 2
2001 VMax VX150TL with EFI on 2002 Skeeter SX190
Son's boat. Bought it new. Said motor idled fine but on last day of BASS Elite tournament following KVD, would not put Skeeter SX190 on plane. Was in heavy rain so I thought from the beginning it was fuel related. He changed spark plugs but no difference. Idles fine but falls on its face upon acceleration.
From reading this forum, I dismantled and cleaned VST filter (was clogged) and the regular see-thru filter. No water. Ran like a champ on small lake.
Called son on out of state job. He said to take the boat to big lake and really put foot in it. Thinks the ignition was breaking down after the engine gets hot. Son has history of always believing the worst. But could it be?
If so, what besides the CDI unit could be at fault?
Presently soaking O2 sniffer in choke and carb cleaner. Sensor was pretty nasty. Will put back together and take to big lake and put foot in it in the heat of the day to see if I can get the ignition to break down, which I dont think will happen. After I hook the battery back up maybe it may store a code.
Somewhere on this forum someone spoke of timing advance rod that strips out but I cannot find the message now. How does the timing advance on this motor? Or what advances it? Crankshaft position sensor? I have found about everything else but I cannot figure out the timing advance.
After I hook battery back up and run it hard, after the weekend, maybe it will store a code. I think the VST was the problem but I will take the boat back to the dealer for testing to determine status of the engine for son's peace of mind. What all should I ask the mechanic to test for?
TPS
fuel pressure
oil pressure
Ignition output
Timing
check for codes
What else?
Thanks for this forum. Very educational.
TPS
fuel pressure
oil pressure
Ignition output
Timing
check for codes
What else?
