hankll
- Sep 10, 2006
- 224
Seems as though most of my problems are over with this motor, took it out the past weekend, spun hub on prop and had to buy another one, changed pitch from 25 to 19 when I did that, so my WOT Revs problem is solved now. But when idling it gets rough, and seems to be fouling plugs. The plugs seems to kick back in when going at WOT. Seems as though the carbs are loading up and I think maybe flooding. So my question is what is idle set screw approximate setting to adjust them? Does the idle set affect the performance of going to full throttle, if set at a more lean position?
