Re: 85 Suzuki DT 115 Excessive Gas Consumption
Now that is more like it. Typically you want to put the motor through 5 compressions. Not sure why the WOT is necessary. I do my checks with closed throttle. Check your spark, make sure all the cylinders are getting a good, clean spark. What did the plugs look like when you removed them? This is important. Keep the plugs in cylinder order so you know what each cylinder is doing. After that I'd do a visual inspection of the fuel system. Make sure there are no leaks or anything. A fuel vacuum and pressure test of the system would not hurt either.
How do you operate your boat? This could come into play as well. Is it loaded down with gear and stuff? Do you go WOT often?
The boat seems to need a check up it sounds like. I'd start running down the list of what could be wrong and eliminate even the mundane silly stuff like battery cables, battery, wiring between motor and remote control, see what may be different from what you remember. Is it propped correctly? Is it at the proper operating temperature?
