So the power tilt/trim stopped working on the boat last night. It worked fine and then just quit. It will not go up or down. Also, you can hear the relay at the back trigger when the switch is pushed either direction, but nothing else happens. Is there anything besides the motor/pump thats behind the relay, or is that the problem?
Any ideas would be welcome.
