This outboard was running fine the other day.
I pulled in, shut down, refueled, and topped off the oil reservoir. Two days later, I started it up and it was surging at anything above an idle. I thought it might be some bad fuel, so I switched to another tank with the same results. I idled around for over an hour and pulled back in. I changed spark plugs, pulled and cleaned the fuel filter, which was not dirty, and checked spark. The indicator light shows the oil reservoir is full. It is still surging at anything over an idle.
Any ideas would be extremely appreciated.
