Remote oil tank will not pump to engine. Float switches are all good. Motor magnets came loose but glued back and motor runs in emergency mode. Will fill with emergency switch. Alarms sound and engine rpms drop as designed when low oil is detected but remote tank does not fill the engine tank. Motor has 6.3vdc when low on oil. It has 12.4 when emergency switch is operated. There is 12vdc to ground from the brown wire at motor. Does this sound like a computer problem. I have checked all I can back to the connector going into CDI unit. I can find nothing bad? Anyone have a clue?
