Re: Suzuki DF115 Exhaust Problem
Based on my reciept for the warranty work, the replacement engine holder kit part number is 51110-90822-OEP. Based on info on the Browns Point part lookup website, that part was introduced beginning at some point during 2003 for SNs 373696 and beyond. FYI, the new engine holder was not compatible with some of the original shifting hardware which was also replaced along with the new engine holder last fall.
I don't have much info on the oil pan leak, but that problem could be linked to a run of poor castings which may have been addressed without design mods. The previous post I referenced was also an engine produced in 2001; like mine...at similar hours. Based on pictures in the Service Manual, there are some complicated casting features at the oil pan leak location since it leaks where the exhaust, oil and cooling water plenums come together. Probably just didn't have enough metal. I'm sure they were working hard to keep the weight down.
The engine is a 2001 with about 400 hours. It is normally used in Salt Water in the Southeast. I'll keep the dealer out of this because I think Suzuki is the source of all the pushback and the dealer seems to be helpful at this point.
