Hello to all..
I have a 2004 Yamaha 4-Stroke 150. I have done a pressure test on it and it leaking at the propeller shaft oil seals. I am going to replace all seals and O-rings I'm starting with the propeller shaft oil seals and O-ring. I have already taken off the ring-nut and claw-washer.Next I want to pull propeller shaft housing. I put the Bearing housing puller and universal puller in place and started cranking down.It seemed like alot of pressure enough pressure to start spinning the drive shaft. Do I need to take the straight key out first? Or is there something else I need to take out first like the the oil seals? The manual does not mention anything. Any help on this would be Greatly appreciated.Thanks Todd Z.
