When flushing engine today water only came out of pee hole and a little out of the holes around lower unit lip(where lower unit bolts to mid-section), nothing was coming out of big hole in the center below the rear of cowl. It seemed not to want to suck water,forcing water out the sides of muffs more than usual.The engine sat for 12hrs. after using in salt water,no buzzer went off, but I only ran it for 5min. although water felt very warm. The engine ran normal last evening.I've only flushed engine 6x but does this sound normal?
Any help would be highly appreciated!
