hankll
- Sep 10, 2006
- 224
I started my motor in driveway yesterday with water muffs on. I wasn't getting to much peehole water coming out. but some was coming out. This motor was just out from mechanics shop for carbs rebuild, and lower unit service, impeller replaced, and I was checking it out after I hooked up electrics to dash that I had a problem with. Thats s now fixed, so while checking motor out I was revving it to top end revs and putting it in gear and revving it. Telltale was still putting out but not very well. After I shut it off water jacket on driver side was cool to touch while other side was fairly hot. Do I have an obstruction in block? Or was muff testing the problem. Should I just take it to the lake and test it with cover off and see if its all right or run it back to the mechanic? I don't want too blow the motor on first trial run.
