Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
Water flow diagram ???- Yamaha '96 C115
  • Water flow diagram ???- Yamaha '96 C115
    Can anyone send me a diagram or schematic of water flow of cooling system for a Yamaha '96 C115? If not for Yamaha the maybe a generic diagram for most outboards. Thanks in advance.
    Re: Water flow diagram ???- Yamaha '96 C115
    I can describe it, but I don't have a diagram handy.
    Water is drawn from intakes in the gearcase.
    It passes through the water pump and continues up a pipe into the base under the powerhead.
    From there it works it's way up into the cooling jackets around the cylinders and in the heads.
    Water fills the cavities from the bottom and is blocked by the thermostats at the top until it opens from heat.
    The next stop is the exhaust system between the cylinder banks.
    It exits with the exhaust down through the midsection, into the gearcase, and out the prop.
    There is also a high pressure bypass valve that allows full unfettered water flow at higher RPMs, and a bit pee's out the telltale.
    Hey, Have you seen? They make Really Cool life preservers nowadays.
    So "Looking Dorky" is no longer an excuse for not wearing one.
    Back to Top
