Re: How much gas should a 2-cycle suzuki use?
A very good rule of thumb for any engine is put a decimal point one position left in the horsepower rating. While not an exact measure of fuel consumption it gets pretty close. Putting a decimal point in the 115 would be 11.5 or 11.5 gallons/hour at wide open throttle. That trick works for virtually every outboard -- two stroke or four stroke, carbed or fuel injected. Ovbiously size of the boat, prop selection, state of engine tune, load and a host of other things affects that but as I said, it gets quite close. So your figure of 13.5 gallons, although a little high, is not out of the ordinary. I have a 75 HP Merc on a walleye boat. I run a fuel flow monitor at wide open throttle -- two aboard, full live well and fuel tank it burns exactly 7.5 gallons/hour at WOT.
