hankll
- Sep 10, 2006
- 224
Just got a DT150, was demo'd running when I went to get it and when I get home and mounted on my boat, no spark, getting plenty of gas ..
what could I look for first that might be likely from traveling with it laying on oil tank side for 675 miles? I thought maybe the oil flow sensor, tried to disconnect and then bypass by putting jumper to the wire harness connectors to the sensor, nothing. So what else could it be? Plugs are wet from gas when inspected. I haven't check all of the harness, CDI is behind plug coils, so haven't pulled that off yet to check it's connectors. or haven't looked under flywheel cover area yet, but other than those areas, everything seems connected. Read somewhere about a kill switch on these but unable to see anything like that around the power head area. Have pushed the reset low oil warning button a hundred times with no results.
Also, if anybody has a owner manual for a Dt150 Super Six, I'd gladly pay them for a copy. Specifically I need info on the remote cable hook up - mine has 2 cables one coming from remote to engine, that hooks into plugs inside engine, then another one that is not connected to anything except on engine side but nothing seems to be matching around remote, so I'm guessing it goes under dash for instruments, but then there is another short cable coming out of box that might be for the instruments, too. I'm cornfused! Any help appreciated.
