This is a pic of the lower unit described above. The motor is mounted on a 2003 Triton TR20. It is mounted 6.5" above the transom which also takes into account an 8" detwiller jack plate that is on there.
I have had the motor running for about 10 hrs, and at WOT for about 3 hrs...
The mechanic at my dealership says it is a "cavitation burn"! Regardless of what he says I want your opinion!!! I've never seen that before!!! I should add that the lower unit looks much better than the picture shows with the exception of the spot in question. There are no other paint problems. But that burn or bare spot is actually down to bare metal in about a dime size area that you can't see in the pic. The other side looks about the same but it is about 25% smaller in size.
I am running 18 psi at WOT and about 70-75 mph...
It is still under full warranty for two years.. Haven't hit anything to cause this.
Thanks in advance...
