rodbolt said:wow, if the crank and rods are not damaged its an easy fix.
try Fridays marine in saluda VA.
what happened to the old powerhead ?
Saved the old powerhead...took it off yesterday on the dock. Not exactly sure what is wrong. Going to take it to a mechanic. Bought Boat used and knew motor had issues. Previous owner took off piston covers and they all seemed to move. leading them to think crank was broken. Maybe the crank and rod are ok...Hard to find anyone in Maine willing to work on it. Including the Suzuki dealer near me. Motor will not run ...barely turns over with the starter. Could not turn over by hand once removed from lower unit.shc14 said:rodbolt said:wow, if the crank and rods are not damaged its an easy fix.
