i have an 85 hp spirit 3 cylinder and its not running on all 3 once in awhile it will but 99% of the time not and when i take and spay fuel in the center carb. it picks up and runs fine. cleaned the carbs. problem still exist's fuel filter is clean gas is good bowls of the carbs were clean im going to try to replace the fuel line from the tank to the engine. what else could be causing me the trouble?
