jimspitler
- Aug 4, 2006
- 13
My motor would run fine for 1-10 miles, then it would bog down, idle rough and only be able to operate at 1500 rpm max. Occasionally, at idle or after a shutdown and start, it would "cough" and idle normally. It would run just fine and do the same thing a couple of miles later, causing me to believe it was fuel. While this was going on, the battery would only charge for about 5 min after the 1st start of the day. I've confirned this by using my multimeter with the battery and it'll show 12.4 V and 5 amps toward the engine(yes, I'm sure). The voltage will also decrease with an increase in rpm. I've changed the fuel and added water absorber/new seperator, cleaned the fuel vapor seperator and filters with no luck. Now, I've confirmed that the left side (#2,4,6) aren't getting any spark at all and the other side is fine.
