Hi there, Hopefully one of you experts can help. First of all the motor had been running fine. It was the first time it ran in about 2 years. It was running strong then I hit a big wake and shortly after that it droped to about 3000rpm. It ran smooth though. I stopped for a minnute then tried to go again. It goes up to that point then it pulses about 500rpm. It doesnt cough like its out of fuel.
I took it home and ran it on the hose. It still does it. It surges between 3000 to 3500. then it will hold 4000rpm but when I try to give it more throttle it does the same thing between 4000 and 4500. I've gone through the Carbs and all the lines. I don't think its in the fuel system but I'm no expert. I've tested all the Coils. They are all within their paramiters except the charge coil. It is 1150 ohm instead of 850 and 44 instead of 120. Can the charge coil cause this problem.
It starts and idles fine. Am I missing something? Any suggestions would be greatly appreciated.
