imported_tigger
- Aug 2, 2006
- 2
The oil tank on the motor is overfilling. Is the float sensor in the tank supposed to shut off the oil pump when it is full?
Ray said:Yes it is. Can also be caused by the control module. Lots of posts on ohming the sensor. If it checks ok then likely the control module.
