Hello,
Is there anyone familiar with the outboard above? I have it mounted on my boat and it's not working properly: below 4000 rpm it seems to misfiring at one cylinder causing rough operation and vibration; I checked a lot of components including throttle valve sensor that seems to be ok, but checking the voltage IN and OUT at its wires I had a doubt: the black and red wire that carries the + tension from CDI unit gives an alternate voltage of about 6 volts at idle, increasing as RPM increase, the green and red wire which is the OUT tension from sensor gives a direct tension of 0.9 volts, increasing (as it should do) as throttle opens... may be the CDI doesn't give a correct tension to make the sensor working properly (anyway, checking the timing with a strobe light, it varies as the throttle is opened)...
On Clymer shop manual I have, there isn't any specification about...
Anyone has worked on it?
Thanks a lot
Sandro
Thanks a lot
Sandro
