i have a 1979 spirit 85hp. ran great till last weekend went out ran fine to fishing location backed off throttle and started missing and would not stay running. if i would start it in neutral with lots of throttle it would run on like one cylinder. got it home ran it with earmuffs and it started out missing bad then ran fine till it warmed up and started missing again. i checked resistance on all 3 coils and all reed the same so i don't believe it to be a coil. i played with it some more and it ran fine for half hour i took it for a test drive and started running on one cylinder again. pulled the plugs and #2 had carbon and #1 and #3 were wet. im suspecting the cdi unit. but any other input is appreciated before spending that much on something that i don't know for sure is the prob.
