Re: 1990 Yamaha 225 solenoid
A solenoid usually has 4 terminals, 2 little ones to switch and bridge the two large terminals. Use a voltmeter or 12v light probe to check for power between the large red wire coming from the battery to the solenoid and ground terminal on battery. If this is successful have someone turn the key and check for power between the wire coming off the solenoid going to the starter and ground. If that didn't work, while still having someone try and start it check for power between the two small terminals.
A bench test is the best way to diagnose a solenoid problem, apply 12v power to the small switch terminals, if you get a click check for continuity on the large terminals.
You could mess around with applying power direct from the battery to the starter, make sure the kill switch is working, but again I think a bench test might be a safer choice... Odd that you lose t/t too, check battery connections?
Seems odd to loose trim/tilt and starter, battery connections clean? Check inline fuses/circuit breaker?
