Going Online
- Jun 25, 2006
- 1
About a month ago was headed offshore when the motor was running great about 5300 rpms. went about five miles and the engine shut off. It started back up started to go again and at approx. 3500 rpms it shut off again. Would run as long as I did not try to push the engine hard. 3000 rpms was it. Took it to the shop, mechanic cleaned the fuel filter screen and changed the plugs. I took it out again and about the same place the engine shut down started and started back up twice. From the third starting the motor ran like a top for sixty mile round trip. Today, I took the boat out for a fishing trip and about twenty miles into the trip running over 5000 rpms, the engine shut down started up and ran fine until I went over 5000 rpms This happened three times. As long as I ran in the 4500 rpm range the motor ran great. has anyone had or seen this problem, if so any recommendations?
