bigshrimpin
- Jan 22, 2003
- 69
My good friend has been through 3 Yamaha service Dept's trying to get a fix an intermittent surging issue on his 1991 Yamaha 250. The motor can run for up to 30 minutes @ cruise 4000/4200 before the surging begins. Surging will drop RPM's up and down from 4000 / 3300 <br /><br />Here's what's been replaced so far: <br /><br />The poor guy has blown several thousand dollars for nothing. If any of you guys have an idea where to go from here . . . I know he'd appreciate it. <br /><br />3 Fuel pumps<br />Carbs rebuilt<br />Fuel Filters<br />Computer<br />Coils<br />Stator<br />TPS<br />Plug<br />Plugwires<br />primer bulbs<br />Check Valve on Fuel Tank.<br /><br />Compression is all around 105/110psi<br />The motor behaves the same way when run off a spare tank.<br />
