Re: 1986 Yamaha 150 oil injection
Is it like a little spill dripping out of the vents at the top of the tank or a constant flow of oil pumping out? It's possible that your tank sensor is restricted so the control module thinks the tank is low. Are you sure it's not overfilling the oil tank while it's running and you just didn't notice until after? The pump is electrical, so if the battery is disconnected and it still activley leaks the only thing I can think of is an actual oil leak, like a broken oil line off the tank.
