I have a 1987 115hp ETX outboard. The previous owner had not used it in the last two years. I cleaned the carburetor bowls and jets (weren't very dirty), I put new plugs in and I hooked up some fresh gas. However, It won't idle without taping the choke on/off. It even has a hard time running at slow speeds if I don't click the choke on when it starts to stall. In gear with some throttle (or with fast idle) the motor surges and gives more power for a second and then returns producing an "uneven" running sound. Full throttle does not feel like full throttle speed. After I gave up and brought it home, I noticed that there was oil dripping out of the carbs. My oil control unit is broken too by the way, I doubt it's related but thought I would mention it. I do have oil in the main tank on the motor, and it does appear to be using the oil.<br /><br />So, can't idle, surging power, oil dripping from carbs. Do those symptoms point to one problem?<br /><br />Thanks.
