grease fitting in lower unit behind prop yam 4stk '02
morayinc
Hi, I cannot find the answer to the question, What is the grease fitting for in lower unit behind LH prop yam 200 4stk '02? :confused: <br />I have not found any post and not a passage in the "C" shop manual.<br /> It looks as though it is on the right side (looking forward) of the bearing carrier housing "fins." What is the lubricant one should use for this location and any precautions? <br />Thanks for the assistance in advance.
rodbolt
Re: grease fitting in lower unit behind prop yam 4stk '02
use waterproof grease. its to aid in corrosion.
morayinc
Thanks for the post. I did not want to make an expensive error.
