Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
ECM?
This topic is closed.
  • ECM?
    I have a 2000 40hp 4 stroke Yamaha that has a Motorola ECM unit. Yamaha part #67C-85540-01-00 My unit has the following numbers on it:M6008JX856178 FSTR9802 4S ECM-3 00MY859544A1 PI91181328. I have found a Mercury Quicksilver ECM unit with some of the same numbers. Quicksilver part #878433A2. Made by Motorola, the following numbers are on the unit: M600D50 856178 FSTR9802 4S ECM-3OOMY PI91720704. Both units share these numbers 856178, FSTR9802, 4S ECM-3OOMY, I'm almost certain that the Motorola part number is the 856178 that both of these units have. Does anyone know if this ECM will fit my Yamaha or is there somewhere to maybe find a cross reference number? I have searched the web over today and found nothing. I have no clue if this unit will match up or not, but if it will fit I will save about $200. Thanks.
    Re: ECM?
    Welcome to iboats. How do you know your ECM is faulty? They're awfully reliable. That would be about the last part I'd expect problems from.
    Hey, Have you seen? They make Really Cool life preservers nowadays.
    So "Looking Dorky" is no longer an excuse for not wearing one.
    • #3
      Re: ECM?
      The motor got to where it would idle but would not plane off. I first thought it was a carb problem, carb was cleaned, but after checking the fire on the plugs the #1 and #3 cyl. is firing, but my #2 cyl. is not firing. We took the #1 coil wire that has fire and plugged it in to the #2 coil and it got fire, so that tells me that the #2 coil is good. What else do you think it may be, the trigger?
      • #4
        Re: ECM?
        test everything carefully. that yam 40 ya got is a merc with a silver blue dress on. it was manufactured by merc for yamaha all the way down to crappy motorola ign components. they never worked well on a merc so we knew they would not be as reliable as hitachi even with a new paint job.the pulser coil resistance,R/W-B, is300 ohms.
        no tech questions by PM, they wont get answered.
        you have to be trusted by the people that you lie to .
        • #5
          Re: ECM?
          Originally posted by rodbolt: test everything carefully. that yam 40 ya got is a merc with a silver blue dress on. it was manufactured by merc for yamaha all the way down to crappy motorola ign components. they never worked well on a merc so we knew they would not be as reliable as hitachi even with a new paint job.the pulser coil resistance,R/W-B, is300 ohms.
          So are you saying that part should work?
          • #6
            Re: ECM?
            it should but I have never tried it so I dont know. anytime your not using the factory part numbers you are rolling the dice. do ya feel lucky ?
            • #7
              Re: ECM?
              Based on Mercury ecu part numbers,it should work. Check a Rapair or CDI electronics manual and see if they both cross to the same replacement number.
              • #8
                Re: ECM Mercury 2000 - 40HP - 3 cyl. - 4 stroke
                Hallo mr Sharpshooter,
                I read this old message because I have now the same problem. My Mercury is the same as the Yamaha you discribed.
                I hope I can get after such a long time still answers:
                - Did you solve your problem(s)
                - What was after all the exact problem
                - How did you solve te problem(s)
                Hope I'll hear from you.
                Thanks JuanVIII
                • #9
                  Welcome aboard JuanVIII. Please don't reply to old threads, you need to start your own thread with your information.
                  Have you read the announcement at the top of this forum? http://forums.iboats.com/announcement.php?f=444
                  Don S.
                  Please, no PM's (Private Messages) regarding boat/engine problems.
                  That is what the forums are for.
                  Only forum/moderator issues will be answered in PM's.
                  Back to Top
