I read sometimes ago at this forum that if your engine seems to wanna quit if you increase the RPM, but picks up the RPM when you partially closed the air inlet opening with your tumb, this indicates that the engine is lacking fuel. When the engine gets hot however, this problem seems to go away.<br />That's is what's happening to mine, so I intend to make the fuel mix richer, but can't find where the screw is in the carb. Would someone(s) help point me in the right direction please, here's the carb's diagram; thanks!<br />
]http://www.boats.net/yamaha/partsystem/browse-model-parts.pl?type=component&*******=cef029d16ac7cd19611648c07985e645&catalog=Outboard&year=1987&model=FT9.9ELH&component=376100[/img ][/URL]<br /><br />031006 19:19 PST url edited...st.
