jurgenscraft
- Nov 6, 2004
- 227
I would like to fit a electrical temperature gauge to my motor, This afternoon I had a good look around the motor and saw,that there is a plugged off tapped hole,on the lower cylinder head water jacket ( consisting of a hex head stainless steel plug )can a temperature sender unit be fitted where the plug is and wired up for the dash mounted temperature gauge,or where else can a sender unit be fitted. where would the correct place be to fit a temperature sender unit to the motor.Kind Regards William Wright
