Re: Yamaha Temp Gauge Sender Question
what type of sender is it? if its a surface mount its ok, if it threads in the block most likly not. the yamaha 2 stroke 150 2.6L the temp sender goes into the block. remove the plug on the stbd side just fwd of the head mating surface on the top of the block, thats the temp sender hole. the port side is for water pressure.<br /> most aftermarket senders can be surface mounted with a little bracket.
