lundwalleye
- Jan 7, 2006
- 1
To drop the lower unit to replace The pump. When the bolts are removed to disconect mciganek2@juno.com the unit from the power head ( engine) does the shaft come out all in one piece... On evinrude motors there was a coupling that discounted the drve shaft. There is not any way that I see to do this. When the lower unit is dropped the pump should be all exposed to replace the housing and the impleller Ect.. Right????? Yhe walleyes are biteing and I need to fix this punp. Really need some advice. <br />thanks for THE HELP IF YOU ANSWER.
