My F60 yammie has an intermittent problem, At times it will idle like a top fuel dragster and during high speed you can feel it cutting out and at other times it runs perfect. If i tilt fully it will run poorly next time it is started.Carbs cleaned several times, little or no trash found and nothing in fuel filter to indicate dirty fuel. Changed plugs,Gas,Tanks.Installed extra fuel filters. No gas running out of carbs to indicate flooding, Pumping primer bulb has no affect, Im starting to think its something else. Valve clearance in spec.
