1987 40 HP Suzuki. When running, fuel bulb shrinks(vacuum). I replaced fuel bulb and have same result. I have tried with vent open and closed on fuel tank. Any suggestion?
The pickup in the tank is probably clogged with debris. The engine is trying to suck fuel through the line and with a clog between the tank and the bulb, the bulb gets sucked flat.
