02 YAMAHA 200 OX66 WINTERIZING
s covello
DO YOU DRAIN THE VAPOR SEPERATOR TANK FOR WINTER LAY-UP? ALSO IS THERE ANY MAINTAINANCE FOR THE 02 SENSOR<br /><br />THANKS FOR THE HELP.
rodbolt
Re: 02 YAMAHA 200 OX66 WINTERIZING
I usually clean the O2 sensor after fogging but some do it after the spring initial start up. yamaha reccomends draining the VST, I usually give it a mix of stabilized fuel and run it with the stabilized fuel for ten minutes or so. if you drain it leave the plug out for at least 30 min to make sure the pump drains. the object is to keep varnish from locking the pump
