Re: 99 yamaha 150 hp trim wants to go up by itself
next time it happens immediatly disconnect the red lead in the thre wire trim harness . its the group of red,light green and light blue wire at the control box. have them prepositioned. if it quits trimming when you disconnect power at the trim switch you can assume its a bad switch. also try operating it with the pan switch disconnected as that switch can fail as well.<br /> if it still randomy trims up it may well be a bad trim solinoid.<br /> but as you refuse to give the model number I cant tell what ya have so I really cant assist.
