Re: YAMAHA 9.9 WINTERIZING NIGHTMARE
Golly -- there certainly were some other options I would have tried before attempting to open the crankcase. The engine is light so why suck the oil out -- tip the little bugger upside down and pour it out. Chances are the tube that got away from you could have been shook out as well. But since you opened the engine, how do you plan to reseal it? Chances are unless the power head is removed it's going to leak oil like crazy. Now that you feel bad, take the engine off the boat if it has not already been removed. Tip it upside down (over a drain pan) and shake it. With luck the tube would slide out. If not, and depending on how hard the tube is that you lost, one might consider leaving it in the crankcase. If its soft enough, it may get thrown around and eventually just lay at the bottom of the crankcase doing no harm. You still need to consider how to re-seal the engine however. That's best done by removing the power head. And as long as you are doing that, remove the pan and extract the tube. Reseal, install the power head and away you go never to repeat the mistake (hopefully).
