Re: Yamaha 200 EFI fuel pump
check to see if your delivery pumps have clear diaphragms. if yes change them. if they havent been serviced in the last 2 years change them anyway. had the exact problem on an sx200txry this summer, fuel pressure would be solid for about 90 seconds at wot then jump 5 to 30psi and rpm would fall right off. basically the vst was running out of gas from a ruptured diaphragm in 1 low pressure pump (would run all day at 4000rpm). i changed all the pumps (cheaper to change then rekit) and the high pressure pump because i didnt trust it after it had run outta gas numerous times.
