Greetings<br />'97 Yamaha S115 TXRV - Temp indicator on digital gauge shows when I turn on the key. Had an over temp condition...seaweed...that caused the audible alarm to go off. Temp indicator on gauge did not light. Traced the wiring from gauge back to the stb side of engine. The orange, black and pink continue on at a square connector. The gray wire dead ends to an empty factory push connector. Is there a harness or connection that needs to be made to get the temp indicator to work on the gauge? Thanks for any advice. Great site by the way... spend way too much time here.
