Getting a 115 HP Suzuki 14 * 19 Alum Prop
mprouty
I have a 2003 115 HP 4 Stroke Suzuki. The original prop is 14" in diameter with a 19" pitch. It has 15 splines. The part number is 58100-90J10-019. <br /><br />I can't find a replacement prop with the same diameter and pitch except throuth a Suzuki dealer where they want $189 for it. <br /><br />It is mandatory that I get a prop of this diameter otherwise my 26' boat has a problem with porpoising. <br /><br />I have found some props that will fit but the diameter is always too small.<br /><br />Anybody know of a source for these propellers that is less pricey than the dealers?
pmassey31545
Re: Getting a 115 HP Suzuki 14 * 19 Alum Prop
Don't know if they are any less expensive, but you can try ******************** or ********************* Both have plenty of parts and accesories. Some are cheaper, some are not. Give it a shot...<br /><br /><br />List the name if you want, but no direct links allowed...Mod1
walleyehed
First of all, diameter has little to do with porpoising, Engine set-up, trim and balance of boat are factors that would affect porpoising...
