RedRustler
- Feb 19, 2005
- 47
I have been away for a bit with the new motor i have been spending more time fishing and less tiime in the back yard trying to fix a problem <br /><br />my new motor has a 15 amp charging system and i was wondering if it would handle two battery's?<br /><br />it would be a trolling battery and a cranking battery with a switch box in between so i could only use the trolling motor while fishing and then switch to both battery's while running to give the trolling motor battery a little boost from spot to spot.<br /><br />i no-one see's a problem i was thinking of using 6 or 8 awg wire from the switch box to the trolling motor battery <br /><br />the box would be installed close to the cranking battery and be about a 11' run to the other battery
