Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
1988 Yamaha Lower Unit Drain Plug Thread Size 130HP
  • 1988 Yamaha Lower Unit Drain Plug Thread Size 130HP
    I bought the pump kit for my Yamaha 250 (1997) to pump in the lower unit oil. Now I have a 1988 Yamaha 130 and the screw in fitting to attach the plastic hose to does not fit. Is the thread size different between the old 130 and my 1997 250?
    Re: 1988 Yamaha Lower Unit Drain Plug Thread Size 130HP
    nope. both are 8mm. both use the same plug and gasket. you have to buy the adapter that fits between the pump and a yamaha. most of the pumps have a 3/8ths thread.
    no tech questions by PM, they wont get answered.
    you have to be trusted by the people that you lie to .
    • #3
      I understand, but what fit my Yamaha 250 does not fit my Yamaha 130, makes no sense. I'll have to take a closer look as it starts to thread and stops hard, perhaps a burr or something even though drain plug goes in out smoothly.
      • #4
        could be some one has heli-coiled one of the motors and used a differnt plug. the top and bottom plugs on both engines share the same gasket and thread size, or they did when they left Japan.
        • #5
          Okay got it. Just went in a little snug and I didn't want to force it, all its good, thanks.
          Back to Top
