I have a 1995 Yamaha 85hp. Recently, the prop spun off. I luckily found the propeller. After I put the propeller back on and turned engine on, the engine was in reverse gear when it should actually be in neutral. So, the prop spins slowly in reverse when started. I do not want to strip the gears out by putting it in gear anymore. Could I possibly have done something when prop spun off to cause this? Do I need to take off lower unit and adjust to neutral? Or is this a whole different problem that has nothing to do with the prop spinning off?
