My outboard is on a Voyager pontoon. It has a push to choke Prime Start system. The electric primer does not activate when the key is pushed in or when voltage is applied. there is voltage to the wire to the primer out of the key when pushed in.<br /><br />The manual primer works fine.<br /><br />Is this a simple primer or is there a variable voltage system that automates the primer system.<br /><br />suggestions?
